The same camera placed in 3 different positions looses often the connection to the base station. I have to remove the batteri and put it in again in order to synchronize. The batteri icon shows 100% charged!
I don't have any problems with the 2 other cameres
Just wonder if I have to get a replacement within warranty
If you have move locations and changed battery a few times and the camera continues the same trouble ( while having good signal ) , then yes... it may be a hardware issue
