Arlo Pro 2 CVR: Is it correct that motion is not recorded on the CVR / timeline?
  • 1 Reply
  • 834 Views
  • 2 Likes
L78
Hi,
I'm using Arlo Pro 2 and the CVR feature. Is it correct that motion is not recorded on the CVR / timeline? It is shown with a green line that motion is detected and the motion is record in the libary, but on the timeline I can not see the record motion.
THX 🙂
If I understand you correctly, you're experiencing a difference in what the timeline shows compared to were in the timeline the recorded video actually resides. This has been reported many times and is still problematic.
Trying to find the actual event noted in the timeline by the green line requires that you slowly adjust the time to a few to many minutes after the event occured. It seem to vary so you just have to slog through the timeline until you find the actual event.
I don't know that there's anything you can do to fix this. I believe it's a server-side issue.
  • 1 Reply
  • 835 Views
  • 2 Likes
