Arlo Pro 2 Base Station will not comunicate with server
  • 4 Replies
  • 17176 Views
GeirJS
Hi.
My Arlo system stopped to comunicate with the server. Everything seems to be ok..
All Leds are green, indicating that it is Powered on, Connected to the internet and all cameras connected.
Tips ?? It worked fine for several months, and one day not.....
Regards Geir
GeirJS
Found more info on the subject in community..
Seems many have experienced similar problems..
Sollution was, use mobile app, and remove all devices, included the base...
Restart basestation, add it using the app, and add camaras...
Works fine now.
Thanks Community 😄
GeirJS
First, just try a power button reboot.... off then on, wait about 2 mins to fully reboot, test
GeirJS
HI.
I have tried that 4 times... Will do a 5.th try now, leaving the power off for 2 mins first...
The base station reboots as if everything was normal....
But... it is not. My app and web page both says "Base offline"....
All leds green, and the midle one blinks from time to time, indicating activity from base to server...
GeirJS
Works fine now.
Thanks Community 😄
  • 4 Replies
  • 17177 Views
