Arlo Pro 2 Base Station Cannot Connect To Internet
Hi, I have been using my Arlo Pro 2 with Nighthawk R8500 since last week in China. It worked well until three days ago, with error message saying the base is offline. I tried all troubleshootings including opening ports 80, 123 and 443 but the base is still offline. I used the same ethernet port for other gadgets and the internet works perfect. Other ports are not working for Arlo Pro as well. Anyone knows what else could go wrong?
WHat are the LEDs on the base showing? Should be 3 green ones.
power=green, all others=amber. Tried all troubleshootings in user manual.
The amber Internet LED means the base is connected to the router but not the Internet. Restarting the router may help. Who owns the router - you or the ISP?
Assuming you haven't made security chnages in the router of any sort, it sounds like an ISP issue. You need ports 80, 123 and 443 to arlo.netgear.com to be open.
The typical router default settings need nothing to allow access for the base. You shouldn't need to do anything for a standard setup. My question was just to raise awareness of whether you made any changes. If not, I would contact the ISP.
I believe some folks have used a VPN to get around certain issues. Don't know if that would help you or not.
