Arlo Pro 2 - Anything to repel spiders and reduce webs?
  • 5 Replies
  • 2806 Views
JoeM845
Luminary
Luminary
I have existing cameras with IR LEDs for night vision. This attrects spiders and I often get webs right in front of the camera. The webs are highly reflective - they obscure the view and also trigger motion alerts. Is there anything in the Arlo Pro 2 to reduce or eliminate this problems?
5 REPLIES 5
No, you need to manually keep them clear.
BTW, I don't think the IR is attracting spiders - I have spider webs in front of cameras that rarely get used.
steve_t
Master Master
Clean the spiders off the camera. Then wipe peppermint oil or insect spray liquid around the base of the mount
V8
Spray spider-X every few weeks
JoeM845
Luminary
Luminary
Thanks V8,
Every few few weeks sounds fine. Much less frequent than current regimen.
I am not able to find USA listings for Spider Ex (the way I see it spelled). Many listings in the UK. Do you know of sources in the USA?
V8
JoeM845 wrote:
Thanks V8,
Sorry buddy I don't; apologies I didn't realise. I would assume there is an equivalent i.e StarBrite Spider Away
  • 5 Replies
  • 2807 Views
