Arlo Pro 2 3 Sec Look Back
  • 1 Reply
  • 1569 Views
SC3611
Capture activity 3 seconds before a triggered event so you’ll always know what happened, from start to finish. Available when plugged in and used indoors. - why does the powered camera need to be indoors? How does the 3 second feature know if the camera is inside or outside?
it doesn't.... Just the fact that if plugged into ac . the 3 second look back feature is enabled.
It must be ac powered as it is recording all the time, when a trigger event happens, the previous 3 secs is added to the created file
  • 1 Reply
  • 1569 Views
