Arlo Pro 2 1080P recording at night
Please let me advised if Arlo Pro 2 can record motions with 1080P at night when outdoor light near the camera turns on. Otherwise, is there any setting to enforce 1080P recording at night? I need color recording at night.
David
For color recording you'll need to provide normal outdoor lighting of your own.
If enough light is present, the Arlo Pro 2 camera will automatically switch from IR nightvision to color video automatically.
____
Please click KUDOS or REPLY If you found this helpful.
The camera will switch from color to B&W depending on the amount of light there is. If you want color recording at night, you will need to adequately light the scene the camera sees. There's no setting to force it and detail in low light is better seen with B&W
