Hi there,
Does anyone know how to set up rules so the motions or sound detected through the cameras can set off the siren?
I followed the mode setting but it wouldn't work. My cell app still receives alerts when I wiggle aroung the camera but the siren doesn't go off. I could however mannually set off the siren but that is not what I am looking for.
Thanks!
Are you sure that after checking the Turn Siren on Box that you are saving the mode for that camera?
In order for the siren to turn ON whenever the camera detects motion, you need to make sure that under rules "TURN SIREN ON" should be enabled. Also, there are fixed time if how long your Siren will alarm if it detects motion.
To turn siren on when it detects motio, go to:
Mode > Armed > Rules for each camera > Turn Siren On should be checked > select how long will be the arlarm time
make sure that you save all the settings you've made for it to be applied on your Rule. Also, you need to change the rule for each camera to have this kind of set up on all your cameras.
