Arlo 2 Pro with Hub & 4 Cameras / 2 locations. Use multiple email logins?
  • 1 Reply
  • 934 Views
SirenBear
2 hubs with 4 cameras each at 2 locations - home and cabin, in order to not have to pay for more than 5 cameras I'm guessing I could use 2 email logins ...1 for home with 1 hub/4 cameras & the 2nd for cabin with 1hub/4 cameras. You have a great product up until I discovered this issue. It should be 5 cameras max per hub (aka location) not per email address. After finding this out, I would have considered a different brand for the 2nd set of cameras...THANKS!
Location doesn't work as many use more than one base at the same location....
You could pay for the service to make it easy
or
you can share account 2 back to account 1 so all are visible at same time
  • 1 Reply
  • 935 Views
