Re: Arlo 2 Pro wifi channel
- Email to a Friend
Just wondering if there is a way to change the base station wifi channel. Mine is on channel 1 which is very busy in this neighborhood.
- Email to a Friend
No way to perform the channel change yourself. The base will scan for the best channel and select that all by itself. If near the router, it will use the same channel that the router is using by design. The base operates like a router set to automatically choose the best channel.
- Email to a Friend
- Email to a Friend
Thank you jguerdat.
I am changing the bse station channell as all my neighbors seem to also be uding channel 1. So this should help.
