I've seen several questions about this, but has anyone found a supplier for replacement charging ports? Both of my outdoor cameras are on CVR mode and have pretty severe degradation of their charging ports. It seems they are easily swapped out if the part is available.
Cheers
You'd have to buy another camera to strip parts out of. If still in warranty, contact support using the link at the bottom here. Never wait to enter a claim since your warranty can run out in the meantime.
To replace the port it only takes a thin long T5 screwdriver to remove the 4 screws holding the front cover then remove the 2 small Philips head screws holding the charge port. A real quick and simple job if the ports are available to buy.
I was able to rig the port from another broken USB device, but it was a bit of effort and a soldering iron. Sadly there seems to be no official way of repairing them.
That's pretty impressive, do not think I have the steady hands for such a job 🙂
Real shame you can't get a replacement USB port or get it repaired by Arlo. There is clearly not enough waterproofing of the port, devices like Samsung Galaxy phones have water resistant ports without the need of a flimsy cover.
