  • 1 Reply
  • 717 Views
Micah94
Is there a certain outdoor wall mount that works with charging while camera stays on wall mount and not have to take it off every time the battery goes dead??
Generally, the newer mounts (not the old originals which I'd think are out of production) use a smaller lock nut to allow the camera to be plugged in. You can replace the existing lock nut with any 1/4"-20 nut that would fit your needs. I don't even use the lock nuts since they only slow someone down by .3 seconds. I screw the camera down completely (~3 turns) and snug it down with a light to moderate touch. That should clear the USB port for AC power.
  • 1 Reply
  • 718 Views
