I'm noticing Best buy is selling a Arlo - Pro 2 2-Camera Indoor/Outdoor Wireless 1080p Security Camera System - Black for $199 but the base is different than the white version. What is the difference if any, besides the color. Good deal? Also, Can I use it with wifi 5.0 ghz?
@rob6465 wrote:
....the base is different than the white version. What is the difference if any, besides the color.
The new base with the Pro 2 cameras does not have the loud siren built into the alarm
The only wifi involved in the Pro 2 system is the connection between the hub and the cameras. Your local wifi does not enter into the picture.The hub is wired to your router.
Just another user
Thank you so much for reply
