Alro Pro 2 Batteries Last 3 Days
I’ve changed settings on my cameras but still can’t get them to last more then 3-4 days. When I upgraded, Best Buy said the batteries would last 6 months before needing a charge.
Don't know about 6 months, but I usu get 2-3 out of the Pro Battery...
Usage is spec at 5 mins record/viewing per day... bad signal and or interference can effect too
Pull battery then replace to reset camera and retest
If NG, remove the camera ( settings/remove device ) and re sync to bring back
My experience matches that of TomMac. Unless there is some odd problem or they are set tor record agressively in a high traffic area, the batteries should last 2-3 months.
