Camera is plugged in and located on the garage. Before the update the camera was great and I only got 1 alert on the phone per event. The alerts were only triggered in the zones, and not from vehicles on the street. I have zones that completely eliminate the road . After the latest update I am getting 2 or 3 alerts per event. Also, I am getting alerts for every car that goes by the house, even though the zones are no where near the street. this has become very annoying and I haven't found an acceptable fix. The road is probably 150 feet away. The camera is poisitioned perfectly, and never had this problem before.
OS: Android
HW: VersionH3
Firmware: 1.125.13.0_31717
I have rebooted the base station, I needed to multiple times to get the update to happen. I'm still getting multiple push notifications for 1 event.
I eliminated the 3rd motion zone and that seems to have fixed the issue slightly. I still get event for motion outside of the zone, just not as much.
Still nothing works and the problem remains.
Just to confirm, do you have an Arlo Smart subscription? What Android device are you using? And have you tried reinstalling the app to see if that helps?
I do not have the Arlo Smart Subscription
I am using a Pixel 2
I have reinstalled the app. That got rid of the multiple notifications. But, it has not fixed the problem and has seemed to make it worse. Even though I finally turned the sensitivty down, I am now getting close to a hundred events a day due to cars moving outside of the action zones or wind or shadows. As of today I am up to 63 notifications. Before the update I was only getting notifications if a person or car entered the driveway or the yard.
i have reset the action zones, no effect.
I have turned down the sensitivity, no effect.
I have reinstalled the app, no effect.
You might want to try re-adjusting the camera to see if that helps. You can read more about it here: How do I optimize motion detection for my Arlo camera?
That makes no sense. So everything is working fine before the latest update, and now appears to not work at all, and you want me to readjust my camera?
It is one of the options to try out. What you could also try doing is turning the camera off/on through settings to see if that helps. Otherwise, let me know if you're still having problems and I can help create a case for you.
Please create a case for me. I had close to 300 alerts in 2 days. I've had to disarm the system to make it stop. I turned the system on and off, disconnected and repaired the camera, etc.
I'm pretty much done with this.
I can do that, but that's not was said previously:
"It is one of the options to try out. What you could also try doing is turning the camera off/on through settings to see if that helps. Otherwise, let me know if you're still having problems and I can help create a case for you."
Hey buckeyeinDC,
I'll send you a private message to gather more information from you.
