  • 1 Reply
  • 2922 Views
Anz
My suggestion is, when making a new mode. There's only two options when motion is detected, which is, do nothing or sound alarm. It might be a good idea to have that camera record? Also, maybe an option to select record and sound alarm if you wanted to.
JessicaP
Hi Anz,
You should be able to trigger the siren while the camera is recording when motion is detected. You can do this by creating a custom mode. You can read how to set it up here: How do I create a mode with different rules for each Arlo Wire-Free or Arlo Pro Wire-Free camera?
  • 1 Reply
  • 2922 Views
