Adding Arlo Pro 2 Base Station
I currently have Arlo Pro with 3 cameras, I want to add another Arlo Pro 2 base station with 2 cameras, can i add the Arlo Pro 2 base station using the same account? I might also just phase out my Arlo Pro base station and just use the Arlo Pro 2 base station, how can I do this? Thanks for your help.
No problem adding the base. If you want to migrate the cameras between bases, remove them from Settings, My Devices and sync them to the new base.
