  • 4 Replies
  • 5383 Views
Antoronto
Hi There.
I've just bought Arlo Pro 2. can i add it to My Arlo pro base station. Show me how to do it. I did so many times but it does'nt.
Thanks.
@Antoronto wrote:
Hi There.
Thanks.
You can do it outside the app/prgm...
A Quick press on the base sync button then press the camera sync button... slow blue to fast blue led means it worked
@Antoronto wrote:
Hi There.
Thanks.
Bwoods1
I am unable to sync the cameras to the base station.  I previously had the devices set up but haven’t used in a month and deleted them when I couldn’t connect.  Tried to reconnect and I’m getting nothing.....
Antoronto
Hi there.
A Quick press on the base sync button then press the camera sync button... slow blue to fast blue led means it worked. I did the same what TomMac showed me. Thanks.
Antoronto
  • 4 Replies
  • 5384 Views
