Issue
I want my system to be alarmed at night, even when I'm at home. The only way to do that now is to manually alarm the system.
Suggestion
Add the geofencing mode in the schedule. This way I can set up my system so that it fits my needs better, and I save the trouble of alarming/disalarming my system manually. For example:
11pm-06am: Alarmed
06am-11pm: Geofence
@TimBach wrote:
Issue
Suggestion
11pm-06am: Alarmed
06am-11pm: Geofence
They did accomodate your use case, but they did it the other way around.
You set the "home" mode in GeoFencing to "schedule", and then you set the schedule to arm the cameras at night (and disarm them during the day). You do need to break up the night into two pieces in the schedule (11pm-midnight; midnight to 6 am) - but they can use the same mode.
@TimBach wrote:
Issue
Suggestion
11pm-06am: Alarmed
06am-11pm: Geofence
