Accidentally put battery upside down in Arlo Charging Station and won't come out. Help?
I accidentally put a battery upside down into the Arlo Charging Doc and now it won’t come out. Help please
That likely will be tough to figure out. I would try long, thin screwdrivers to see if you can pry it out. If you can fashion a long, thin hook (crochet hook?) that might work, too. A strip of metal with a small hook on the end might be the trick.
