  • 1 Reply
  • 1000 Views
Ames
I am remote and cannot access my Arlo Pro 2 camera devices.  They have always worked without problems.  They shut off several weeks ago and I cannot access them.
Can anyone help with this?
DannyBearAgain
There is little that can be achieved if not at site.
You can restart the base station remotely from the base station settings page if you still have access via the app.
 If you remove devices from your account you cannot add them back until your onsite with the app connected to the local network router.
Going forward install a smart plug on the base station power adapter to allow you to remotely power cycle the base as needed.
I use them on both base and camera to give me some remote reset ability although if it is a firmware bug you have to wait for another update release to get it working again.
  • 1 Reply
  • 1001 Views
