Hi,
Please, could you advise on best solutions or products (wireless) to get an external alarm connected to the base station of ARLO PRO 2 ?
Maybe look at Smartthings. The cameras can basically work as motion sensors and trigger other things
Hi,
It would be helpfull to get from the Arlo technical support, a complete tutorial to explain how to set-up the parameters and the rules, in the Arlo base station to drive via "smartthings" or IFTTT an external alarm (supporting "smartthings" or IFTTT protocols).
And also if there are recommended products by Arlo, to buy external alarms linked with Arlo Pro 2.
Regards
Hugues75009,
For more information on how to use Smartthings with Arlo, take a look here: How to connect Netgear Arlo Cameras
