  • 4 Replies
  • 4927 Views
  • 5 In Conversation
nancymartin
Does the Arlo Pro 2 hardware (base or cameras) support 5ghz yet?
No..the base uses only etherent, the cameras use 2.4ghz to the base for better range.
Only the Arlo Q cams and Baby use 2.4 or 5 ghz ( hook directly to your wifi without base )
The likely reason for using 2.4GHz is the increased range possible. The higher the frequency, the more easily the signal is blocked.
steve_t
Master Master
As above, not just range as in distance but 2.4 has a better ability to pass through building materials
michaelkenward
Sensei Sensei
Sensei
Why would you want 5GHz?
Do you have a problem that needs fixing?
Just another user
  • 4 Replies
  • 4928 Views
  • 5 In Conversation
