3rd Party App to Download 24/7 Recording
Are there 3rd party apps to help me download 24/7 recording from Arlo Pro 2 camera without me having to spend hours creating hourly clips then download them individually especially with 4 cameras covering different rooms. Cloud storage for 30 days doesn't work for me. I need all long 24/7 recordings stored permanently and not just motions or clips.
Sound like Arlo isn't the camera to fit your needs....
for your requirements, you may need wired cameras
The Arlo Pro 2 is wired and so is the Nest IQ Indoor. Both have the same problem and only allow storage in the clouds for 30 days. I heard there are 3rd party apps that can fix this issue but I can't find them.
is there even a number of email address to contact the Arlo Support Center? I am able to download but not able to view the footage.
No email but cht and phone:
Try the free VLC viewer to play downloaded videos.
