3 out of 5 Arlo Pro 2 camera will not detect motion/sound. They all have push notifications on.
I have 5 of these cameras they all worked fine but 3 will not detect motion or sound. The items are turned on as well as the push notification. The other 2 work fine - any ideas
You need to bring these 3 Cameras near to the Base station and Remove the cameras from the Arlo application.
For removing cameras you can go to settings > My Devices > Camera > Remove.
Then Remove the Camera battery and Re-insert the batteries back in and Sync the Cameras.
Verify it now if it still doesn't work restart the base station from Arlo Application.
Settings > My Devices > Base station > Restart.
Wait for some time until the camera comes online.
Check now.
Thanks.
