I have 5 cameras connected to my base station. Four of them will livestream but this one will not. It does collect data and records when there’s motion and it shows up on my library it just will not connect for life streaming
Try removing the camera from your account and onboard it again to see if that helps.
I have all 4 of my cameras not livestreaming, not sure if it is due to an update... I also get my notifications and recordings, just not showing the live feed.
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
On my end I was able to solve my problem by re-sync all 4 cameras with the base. Now they are all working fine.
