1 of 6 Pro 2 cameras won't connect. Blue LED flashes once and then nothing?
  • 2202 Views
stevendix74
My problem system came with 6 and worked great. All of a sudden 1 camera won't connect. I put a battery in it, the blue light flashes once. After that nothing. Has my base station somehow dropped to 5 cameras? Or does my 6th camera need repair?
Hopefully not, since they aren't repairable.
Did you try swapping the battery with another camera?
stevendix74
I swapped the battery several times.
Then I deleted another camera, and tried adding the problem camera.
I reset the whole system.
It has to be the camera.
I put the battery in, and 1 blue light blinks 1 time. Then nothing.
Is there a repair kit, maybe for wifi system??
Use the Contact Support link at the bottom here for possible faulty hardware.
  • 2203 Views
