- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Performance-Tips-QA-2021-02
- Why does the system alert when "events" such as mo...
Why does the system alert when "events" such as movement occur outside defined zones?
Options
- Mark Question as New
- Mark Question as Read
Accepted Solutions (0)
Answers (1)
Answers (1)
While activity zones will limit the number of recordings in your library, motion that occurs outside the zone will still be detected and cause a trigger. For activity zones to work, motion must be detected and analyzed by the cloud to determine whether it occurred within the zone. If the motion was outside the zone, the recording is discarded and will not appear in your library. When your camera is triggered by activity inside or outside the activity zone, this consumes battery life. Repositioning your camera or adjusting sensitivity may be needed to reduce battery consumption.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
0
Likes
