- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Performance-Tips-QA-2021-02
- What is the vertical viewing angle of the Arlo Flo...
What is the vertical viewing angle of the Arlo Floodlight Camera?
- Mark Question as New
- Mark Question as Read
We went with the Arlo video doorbell for our front door because of the vertical viewing angle showing the area right in front of our door where packages are often left. I currently have a set of floodlights mounted at about 10 feet in between our 2 garage doors and was thinking or replacing them with the Floodlight Camera. I would need the camera to have a similar viewing angle as package deliveries are sometimes left close to or just outside the garage doors (the area that would be immediately below the floodlight). If the light is angled downward to appropriately light up the driveway, would the camera pick up the area almost directly below it?
The Arlo Pro 3 Floodlight Camera has a Field of View of 160 degrees diagonal. Please find the following article with information on best positioning here: How should I position my Arlo Pro 3 Floodlight Camera?
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
