- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Performance-Tips-QA-2021-02
- My floodlight camera is showing green lines over t...
My floodlight camera is showing green lines over the recording and live stream
Options
- Mark Question as New
- Mark Question as Read
Hello,
I am getting poor quality recording from a recently purchased floodlight camera.
I initially thought it was the wireless signal, so I greatly boosted that. However, it still doesn't work. I am now getting great recordings from the doorbell camera which is located very close to the floodlight cam.
Answer
0
Likes
Accepted Solutions (0)
Answers (1)
Answers (1)
The symptoms you describe are often related to poor signal strength or WiFi interference. Consider temporarily relocating the camera to a different location and test to see if you experience the same results. This will help isolate if the problem is with the camera or the location.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
0
Likes
