- English
- Services
- Arlo Home Security System
- "Secondary Security PINs and Duress PIN are disabl...
"Secondary Security PINs and Duress PIN are disabled"
I'm having the exact issue in the following forum post, and I"m not sure how long this has been a problem. My alarm was triggered b/c suddenly, secondary and guest PINs aren't working, despite me having purchased a year-long Plus plan. I'm absolutely livid about this, that a feature would just stop working for a security system??? You guys are opening yourselves up to some serious liability. You need to get this fixed ASAP. What else might not be working that I haven't discovered yet?
I also expect to be compensated since I'm paying for features that aren't working. I have the unlimited Plus plan, which includes extra PINs as I was allowed to set them up when I purchased all the equipment.
https://community.arlo.com/t5/Arlo-Home-Security-System/Secondary-PIN-s-not-working/td-p/2441667
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
