Wire-free keypad urgent feature parity required
As noted in Arlo Home Security System post https://community.arlo.com/t5/Arlo-Home-Security-System/Wire-free-keypad/m-p/2332272?search-action-i...
This is a much needed feature that is holding the wire free keypad back. It was bad enough that Arlo failed to integrate Arlo Chime 2 into the security system for door access. Now you have a split ecosystem where Arlo Video Doorbell 2nd Gen / Arlo Chime 2 work one way and Arlo Home Security System only partially works another. Arlo in moving into whole home security should have understood the vast differences in layouts and minimal feature parity and expected use of competitors offerings. We have invested in 2 Arlo Pro 3 Floodlight Camera s ,# 8Arlo Pro 4 Wireless Security Camera s (which were promptly discontinued), 1 Arlo Video Doorbell 2nd Gen , 1 Arlo Chime 2 , 1 Arlo Home Security System , and 10 #All-in-one Sensors (we need 10 more, but are not proceeding until access entry chirp is available on the #wire-free keypad or integrated into Arlo Chime 2 .
Please update on both of these optional paths progress. Available for beta testing to help if useful.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
