- English
- Services
- Arlo Home Security System
- Went from vbm4000 to vbm4540 my system not recogni...
Went from vbm4000 to vbm4540 my system not recognizing vbm4540
I used Windows 10 and bought the base station vbm4000 with three cameras in 2015; the system worked fine, but with the updated software, my cameras stopped working last weekend. I bought a new base station vbm4540 and three new cameras that come together in a package. ARLO does not recognize the base station. I have tried all of the suggestions and had no joy; however, the little blue light is on. I am using an AUSA ax3000 dual Band WI-FI Router; it worked great with vbm4000. So, I hope that support will have a quick answer, as the little instruction sheet says.
Thanks,
Roger
Did you reset the hub?
https://kb.arlo.com/1057976/How-can-I-factory-reset-my-Arlo-SmartHub-or-Base-Station
You might want to try using a computer browser (my.arlo.com) to see if that works better.
Also, the old cameras can be made to work by asking the mods ( @JamesC , @ShayneS , @BrookeN ) to run the backend sync that can resolve the issue.
Hi @Roger435
I see you still have not been able to get your new SmartHub installed. I went ahead and escalated this for you and support will be reaching out to you as soon as possible. You can find your escalators umber here: 44176332
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
