Random offline and endless chime from alarm base
Has anyone ever experienced their alarm base unit randomly go offline, then start a faint repeated chime? It’s as if the unit is glitching / crashing, and I have to completely power cycle it to get it back in a good state. Anytime a sensor is opened in this state, the faint chime adds on top of any other playing chime repeatedly 😂
Before calling support, try removing the security hub and sensors from your account and reset the hub. The directions are embedded in this FAQ part way down:
https://kb.arlo.com/000062965/My-Arlo-Keypad-Sensor-Hub-is-offline-how-can-I-troubleshoot-it
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
