Uk
I have recently had new EE fibre installed. Since changing the router, the base station cannot be discovered on the app or the browser. I have vmb5000 and vmb4540 and neither works. However Arlo essential XL has connected to router with no problems.
i have tried all resets etc that’s suggested and even tried to switch the 5ghz WiFi connection off to no avail.
as far as I can tell, I have tried everything. I have 3 cameras that cannot be connected without the base station. Any help or suggestions are welcome.
Fixed, factory reset the router and sorted it out
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
