Home
  • 1 Reply
  • 39 Views
AlleyKats95
Has anyone ever added a Netgear base station for their Arlo system?
If this
  1. a base you used before?
  2. a used base you just purchased
  3. a "new" base you just purchased (old inventory)
  4. a base you are thinking about buying?
  5. something else?
You might be able to install it, but that is not guaranteed.  Arlo was a Netgear product line until Netgear divested it in 2018.  You might not be able to install "Netgear" branded bases with very old firmware, because the Arlo servers were shifted from Netgear.com to Arlo.com (so the old firmware can't reach them).  If the base was purchased used, then another potential problem is that you can only install the base if the original owner remembered to remove it from their account.
If you are considering a purchase, then it is best to get one of the newer smarthubs (VMB4540 or VMB5000).
