Sync Door Sensor
After I replaced the battery in the door sensors I can’t get them to sync with the keypad hub- any suggestions?
Assuming the battery is inserted correctly (I'd think it would be nearly impossible to do otherwise but verify the contacts (and battery) are actually clean and connecting), they should just automatically connect. Does the LED on the sensor ever blink? Check page 9 on this document:
Were you able to get the sensors to connect?
I still can't get my sensors to sync with hub after changing out the batteries in each one.
I have looked at the manual and followed the instructions and every time I get the message,
"All-In-One Sensor was not found".
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
