I purchased the security keypad hub and have a trial membership for monitoring. I have set up the emergency contacts and other information required. To test the monitoring response I manually activated the panic button. I let the panic siren run for the total 3 minutes set in the application. I received no call or text from the monitoring service. How do I verify that monitoring taking place?
This issue has been resolved. I sent a message to the support team and they provided the steps below. After doing the first item (cycling power on router and hub) this issue was resolved.
to isolate the issue, we request you to follow the below troubleshooting steps:
- We request you power cycle the router and keypad sensor hub and check again whether you received the call or not.
- Kindly perform the factory reset on the keypad sensor hub. If the issue still persists, Kindly share the below information.
- Kindly confirm the internet upload and download speed.
- Kindly confirm how many Arlo and non-Arlo device is connected to the internet.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
