- English
- Services
- Arlo Home Security System
- Re: Need Assistance: Some, but not all, All-In-One...
Why do some, but not all, of my All-In-One Sensors have an icon under modes indicating "Devices with this icon will trigger an emergency response"? Only some of my sensors have this icon, so I'm confused why some do and not others. Is there a way to turn this On or Off? I have been unable to locate this option if one exists.
Your plan does not cover emergency response. You would need the Premium plan with ER and 24/7 professional monitoring.
Thanks for the response but your reply does not answer any of the questions asked.
Again, why do some, but not all, of my All-In-One Sensors have an icon under modes indicating "Devices with this icon will trigger an emergency response"? Only some of my sensors have this icon, so I'm confused why some do and not others.
Regards.
The icon is typically tied to whether or not an "Activate Panic" action is enabled. If you disable the action then the icon wont show, but there is no button to control the icon itself.
Also keep in mind that not all devices can activate panic. You cannot assign a camera that action. That is more than likely the reason you are only seeing it on certain sensors.
Thanks, but that must not be it because only one of the 1 of the nine all-in-one sensors had panic selected. I unselected it and the icon did not go away. Keep in mind 9 out of 12 total all-in-one sensors are showing this icon.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
