NZ
  • 1 Reply
  • 2062 Views
_TJ
I updated the arlo app. What a nightmare.
It makes no sense to me. Not intuitive at all. The new language used does not reflect the function. How on earth do I work out how to schedule armed and disarmed.
"Standby" is set up by default to be the same as "Disarmed".  Similarly "Armed Away" by default should be the same as "Armed".
Schedules are set up differently - you need to create an automation to run each time you want the schedule to change, and have the automation change the mode to the one you want.
