- English
- Services
- Arlo Home Security System
- Re: Multiple Notifications that stop basestation t...
Hello. Im having a BIG issue for the past 4 week. Let me start byt the begining… I have 13 cameras in total and 3 of these are facing the front of my house and they are located outside. I had no particular issues to send smart notification (1 arlo pro 4, 1 arlo pro 5k, 1 doorbell) 4 weeks ago i started to get 2 notification on each cameras onces a day. Not knowing what were causing this to happen, we realised at the end of the day that the base station went offline from the time we received the 1st double notification. 3 cameras sending a notification means i was getting 6 notification in a row for each time the cameras trigerred something. End of day i had to restart the basestation and everything were back to normal. from the day it started up to now (4 weeks after) i now have that same issue 3-4 times a day per camera per trigger and i now have to reboot the base station 4-5 times a day! This is unbelievable. Please help.
Yesterday i did another test and i removed most of the smart notification i had “on” for each of the cameras facing the front of the house and since i have less notification showing on my phone, the base station disconnect to the network and have to restart the system on and on and on. PLEASE HELP!!!
@Jgosselin Is the base station going offline, are you receiving an offline message in the Arlo app?
Are you still receiving duplicate notifications? Can you provide a screenshot if so?
I do receive multiple notification as you can see on my screenshots. As for the offline, not for the past 2-3 days si ce i removed some notifications settings.
@Jgosselin Can you try removing and reinstalling the Arlo app?
Short answer is “yes” i did. Still same problem. The long answer is “NO” i will NOT reinstall all my cameras (13 in total) for the 10issssh time. This problem wasnt there 2 months ago, please fix on you end. Regards.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
