LBB1001-100NAS Cellular backup and Battery
Does anyone know how long the battery last before needing to buy another one. I'm talking about the life span not how long it will keep the system going in a power outage. Also is it a good idea for maintenance to unplug the security hub and let it run off of the battery once in a while. Arlo only provides at best bare bones documentation. Thanks Gary
That's a hard answer to give without more knowledge as to the internal battery/charging system....
But assume it is as normal for arlo and that the battery is ok sitting at a float charge of 80% of full.
Normal charge cycle for li-ion batteries are in the 300-500 range for full charge BUT when charged to a lower rate number of charge cycles can be increased.
I would estimate at least 3 yrs plus.
lithium-ion cell charged to 4.20V/cell typically delivers 300–500 cycles. If charged to only 4.10V/cell, the life can be prolonged to 600–1,000 cycles; 4.0V/cell should deliver 1,200–2,000 and 3.90V/cell should provide 2,400–4,000 cycles.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
