I'm considering buying the Arlo Home Security System but have a question about the Keypad Sensor Hub. Does it function as a "base station" in the way that the Arlo SmartHub does? Specifically, I want to know if the Keypad Sensor Hub can connect directly to a WiFi router via ethernet to provide a more stable connection for accessories, in particular an Essential Wire-Free Video Doorbell, etc.
A side note: it's kind of ridiculous that I can't speak with a live sales agent to clarify questions like this... I don't have a paid subscription but that's because I don't even own the product yet!!
The security hub does not function as a base station - only the sensors connect to it. The hub only uses WiFi to connect to your router - there's no Ethernet port.
Thank you! Good to know. It seems strange that it wouldn't be able to function as a base station/hub as well.
It can function as a hub for SecureLink-enabled cameras. As of right now, only the 5S has that capability. Older cameras cannot connect to it.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
