When the app last updated, I lost the ability to just arm my outdoor cameras. There seems to be no way to do this anymore, I have an ultra and the flood the used to be able to arm separately. As I have a dog inside, I don't want to arm those cameras. This renders half my needs useless now. I am app app version 5.6.0
You can modify the three built-in modes
So you can arm 3 combinations of cameras. For example, you can use Arm Away to arm all the cameras, and modify Arm Home to just arm the outdoor ones (or just arm the indoor ones if that suits you better).
You can also go into the device settings for the floodlight and ultra, and turn them off when you want to disarm them.
thanks this worked
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
