  • 2 Replies
  • 305 Views
josh1138
When the app last updated, I lost the ability to just arm my outdoor cameras.  There seems to be no way to do this anymore, I have an ultra and the flood the used to be able to arm separately.  As I have a dog inside, I don't want to arm those cameras.  This renders half my needs useless now.   I am app app version 5.6.0
You can modify the three built-in modes
So you can arm 3 combinations of cameras.  For example, you can use Arm Away to arm all the cameras, and modify Arm Home to just arm the outdoor ones (or just arm the indoor ones if that suits you better).
You can also go into the device settings for the floodlight and ultra, and turn them off when you want to disarm them.
josh1138
thanks this worked
