So only had security system for a month now and the all in one sensor batteries are already dead. Anyone else having this issue?
How is the sensor being used? Is it possible there's an issue with the signal between the sensor and hub, whether strength or quality?
Just using them for doors when they open and close and for motion. But motion is disabled when someone is home. It is rated to last a year. Signal is good the hub is downstairs and doors are close by.
ANy chance a wireless device is nearby the sensor? It could be interfering with the signal between the sensor and hub.
I suppose swapping sensors around could be useful to test.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
