- English
- Services
- Arlo Home Security System
- Re: Help Finding favorites continued NEED MARKED a...
I just upgraded to the "new" layout, and I'm having trouble finding the video clips I've marked as favorites.
I know I can set a filter so that only favorites are displayed, but that's not what I'm trying to do: I want to list all my video clips, but I want my favorites to be marked so I can see which ones they are.
This was trivially easy under the old layout, but I can't figure out how to do it under the new layout. Is it possible?
Thanks for your help!
Best answers
Hi all,
This feature is being rolled out gradually now. As it continues to release and you receive the update, you should be able to view your favorited content in the Feed section via a star logo.
Thanks for your patience
HI, Just wanted to let you know the team is still working on enhancing this feature. I'll provide more information as it's received.
Hi @HMishkoff
We are listening to the feedback on this change. To favorite a recording, you can navigate to the Feed section > Swipe right on a recording > More > Select Favorite. To see if a recording is favorited, you can filter the feeds from the top right (3 Dots) or swipe right on the recording.
Hi @HMishkoff
BUT... you can't look at a list of video clips and see at a glance which ones are marked as favorites, like you used to be able to do.
Here's why that's important to me: I have four cameras in active areas, they fire quite often. When I go to the Arlo tab in my browser (I work at home), I watch the new video clips, and I mark the most recent one as a favorite. Then an hour later, when I go back to the Arlo tab, I can see at a glance which clip I viewed last and pick up from there. At least, that's what I USED to do.
That wouldn't even be necessary if there was some easy way to know which clips have been viewed and which clips have not been viewed, but there doesn't seem to be one. Marking my most recently viewed clip as a favorite worked until the software upgrade, but now there's no way at all. 😥
As the post #3 states there needs to be a way to view all the feeds and clearly show which are marked as favorites. The old version would show a matrix of 3 or 4 across and multi rows down. Clearly marked with a yellow star. PLEASE BRING THAT VIEW BACK!
I agree- please bring that feature back soon!
Also need to be able to select all items for deletion but NOT delete favorited items!
These two options are very important. Thanks!
This is still actively being worked on by the team. I’ll follow up with additional details as soon as there are updates to share.
Just wanted to let you know this enhancement is still in the works. I'll continue to provide updates.
Hi all,
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
