- English
- Services
- Arlo Home Security System
- Does this send a signal out as soon as a sensor is...
Does this send a signal out as soon as a sensor is triggered and then send one out after code input?
My current system sends a signal to me or my monitoring station upon triggering a sensor. If no code is entered within 30 or so seconds, it sounds the alarm. If a code is entered, a signal is sent back to the CO and everything is disabled. If someone attempts to break in, disconnect the phone line, tamper with it prior to the 30 seconds the CO doesn't recieve the disarm signal and dispatches. Does the Arlo Home Security Alarm do the same thing by sending a signal to the user or CO as soon as a sensor is triggered and operate in the same fashion? Thanks
If someone other than Arlo's Shayne could reply, I'd appreciate it. There's no button to reply when he responds to my posts and securelink has nothing to do with my question.
Message 1 of 1
209
0 REPLIES 0
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
