Does this send a signal out as soon as a sensor is triggered and then send one out after code input?
  • 0 Replies
  • 476 Views
  • 1 In Conversation
Jshoe
My current system sends a signal to me or my monitoring station upon triggering a sensor. If no code is entered within 30 or so seconds, it sounds the alarm. If a code is entered, a signal is sent back to the CO and everything is disabled. If someone attempts to break in, disconnect the phone line, tamper with it prior to the 30 seconds the CO doesn't recieve the disarm signal and dispatches. Does the Arlo Home Security Alarm do the same thing by sending a signal to the user or CO as soon as a sensor is triggered and operate in the same fashion? Thanks
If someone other than Arlo's Shayne could reply, I'd appreciate it. There's no button to reply when he responds to my posts and securelink has nothing to do with my question.
0 REPLIES 0
