Disconnect and Reconnect Issues
Please see the attached pictures. Almost all the time when I change the status of my security the WiFi and power state that they're disconnected, then immediately it states that its reconnected.
Hi @dansham
Are you adjusting settings on your home wifi network? Can you provide more detail regarding your inquiry?
When the security hub goes offline you will receive a notification for the offline and back online status. If you have the battery backup, you will receive additional notifications for the alerts as seen in your screenshots.
Hi Shayne,
No, I'm not adjusting the settings on my WiFi.
Basically, whenever I put the unit on Standby mode, or Alarm Home mode, via the keypad, I would get all those notifications.
It does not happen all the time, but randomly.
I do receive the notifications that it goes offline and online, but if you look at the pictures its instantaneous. I know the power and WiFi are good, so I'm assuming those are glitches.
Hi @dansham
I have escalated this for you and Support will be reaching out to you as soon as possible.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
